Can't data log at 8192
Old Oct 18, 2007 | 09:42 PM
nbays1975's Avatar
Car: 88 GTA
Axle/Gears: 10 bolt rear w/3.73 richmond gears
I just got my usb to serial cable and tried to do some datalogging in Tuner Pro RT. The first attempt at 8192 almost worked. I got the "connected" message and started getting data. But most of the data was junk. The PROM ID was right, but none of the data values were. So I stopped logging, checked everything, and tried again. This time Tuner Pro wouldn't connect at all at 8192. So I tried 160. No problems at all. It will connect and collect data just fine at 160 baud, but at 8192 baud it won't connect at all. Any thoughts? I am running this on Linux (through wine) and using a usb to serial converter. I realize that this setup could be problematic, but everything works flawlessly at 160 baud, so I think the linux/usb thing is ok. Any thoughts?
Old Oct 18, 2007 | 09:45 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Can't data log at 8192
What version of TP RT are you using?
I'm finding a problem for me with the lastest release, in XP.
Old Oct 18, 2007 | 10:01 PM
nbays1975's Avatar
Car: 88 GTA
Its the latest version (4.14.0365). I just downloaded it today.
Old Oct 18, 2007 | 11:26 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
i don't have a 165 so i could be wrong, but if im not mistaken, the 165 ECM is 160 baud.
Old Oct 19, 2007 | 08:54 AM
nbays1975's Avatar
Car: 88 GTA
I did a search and the 165 ecm can do 8192 if the right code is loaded. I am using ARAP with 6E mask so I think I'm good.
Old Oct 19, 2007 | 11:53 AM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
if it's the factory '165, you might want to borrow one from someone to verify it's not the ecm. They are notorious for having problematic connection issues, supposedly due to poor solder reliability. It would rule out if the connection problem was on the PC side of things, or on the car side of things.
'165 will transmit at 8192 baud. using 32b or 6e, it works. I believe only with 32 (early code) does the higher speed not work correctly, and may be why the ecm is always incorrectly referenced as 160 baud only.
Old Oct 19, 2007 | 10:19 PM
nbays1975's Avatar
Car: 88 GTA
Turns out it was the serial converter. I took my desktop computer out to the garage and started it up with windows. Result was datalogging at 16 works on serial port and usb->serial converter. Logging at 8192 only works on serial port. The funny thing is that the cable test passed with the serial converter. I know some serial converter have issues with TPRT, but I don't understand why it works at 160 but not at 8192.
Falcon50
Aug 22, 2020 03:26 PM
L98GTA87
Oct 19, 2015 10:43 PM
bjpotter
Oct 4, 2015 07:48 PM
BWilcox
Sep 20, 2015 12:19 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
