58mm TB help
Old Oct 20, 2007 | 11:03 AM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
58mm TB help
Well Im running a Miniram'ed 383 10.7 cr, with pocket ported TF 23* heads, TPIS ZZ409 cam with 1.6 rr, SLP shorty headers and Flowmaster 3" cat back exhaust, run off a GM 730 ECM. I had a 52mm TB on the car and just upgraded to a 58mm, so I was looking for a little direction on where I should go next for my tuning.
Ive done some searching but it dident turn up the results I was looking for. Im not looking for a "what do I do next" kinda thing, but more of good direction to get pointed to. Thanks in advance.
Old Oct 20, 2007 | 10:16 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Re: 58mm TB help
Mostly...set the min. air and IAC manually then check out the A/F ratio. Your timing won't change more than likely...just fueling.
Old Oct 20, 2007 | 10:19 PM
Randy92Z's Avatar
Engine: Miniram 383
Re: 58mm TB help
I did set the TPS and IAC, and figured I would need to do some fuel trimming due to the fact that the TB is now letting in more air. I was not sure if I should hit the AE or the main fuel table.
Old Oct 20, 2007 | 11:36 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Re: 58mm TB help
In open loop, the VE needed to be changed a little but the AE was fine. Its more PE or 90-100 kpa.
Linson
Oct 24, 2025 02:00 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
IROCNParts
Sep 24, 2015 10:50 AM
Thornburg
Aug 27, 2015 08:33 PM
