BLMs 110 at idle, 150 at full throttle?
Old Oct 30, 2007 | 08:04 PM
torqueaddict's Avatar
Car: 89 GTA
Engine: 5.7 ZZ4 Vortec TPI
Transmission: 7004R
I've been trying to get my injector setting right. It's always lean under load, and the lower I set the constant it feels like it cuts out when I gun it. Could it be a weak fuel pump? My injectors are basically new (and flowmatched) and I have my AFPR is cranked up to about 55.
I'm running a 5.7 Vortec TPI with ZZ4 cam, and I am using a bin file from another member with my setup except he has 28lb Z06 injectors and I am running 21 lb Accel injectors. (he had his injector set to 22) I've been lowering my injector constant 2lbs and doing a run. I was getting knock (where he wasn't) It seems like it helped to a point but I am theorizing my fuel pump may not be able to handle the demands.
Any opinions??
http://members.bellatlantic.net/~dantill/15.csv
http://members.bellatlantic.net/~dantill/17lb.csv
http://members.bellatlantic.net/~dantill/19lb.csv
http://members.bellatlantic.net/~dantill/21.csv
Old Oct 30, 2007 | 09:21 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
Re: BLMs 110 at idle, 150 at full throttle?
im so new to this so take anything i say with a massive grain of salt
ive already read that if you turn your injectors up too high there is just too much pressure for them to open/atomize properly.
maybe backing it down to around 48 would help? 55 seems excessive
also have you been putting more fuel into the ve table?
Old Oct 31, 2007 | 09:48 AM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Reading BLMs at WOT is worthless....you need a wideband oxygen sesnor. If you are worried that you are lean.....add fuel to the Enrich Power table or in the 90-100 kpa cells in the VE table.
I always set the fuel pressure at the constant they are rated too or no more than 48 psi and tune it with the tune.
Old Oct 31, 2007 | 10:44 AM
Car: 89 GTA
Transmission: 7004R
Thanks for advice. I will try this again at 43.5 pressure.
(FYI: if you open Excel and do file -> open and paste the addresses listed above the files will open right from the web into excel)
BLM is also high at partial throttle sometimes. In the case below I am at 138 @ 1500 RPM, TPS @ .57
Record #TimeStampSpeedRPMKnock CountsKnock RetardTPS VoltsCool TempFuel TotalFuel Trim CellIA TempIAC PosLoad VarLTerm-CLTerm-PO2 VoltsO2 XcntsSA ComputedSpark Adv Units-->mSMPHRPMCountsDegreesVolts°CmSNumber°CCountsCountsCountsPercentmVCountsDegreesDegrees
590566396838150020000.5786.8366.2462914249138590666409238120020000.5786.8376.14462914057138590766420238120020000.5786.8382.78262913955138
Old Oct 31, 2007 | 02:05 PM
91chevz71's Avatar
I don't know much about port fuel, but it sounds like your BPC is off along with the VE table being off. Do the math for your projected max HP and come up with your BPC based on how much FP your max HP dictates through the injectors. Drive that around and see where your BLM's are. Like Yenko said...tuning with a NB O2 is inaccurate when compared to a WB O2. Almost dying when you stomp it sounds like AE being off also. Are your two engines identical except for the injectors?
theshackle
Sep 17, 2020 08:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
ezobens
Aug 19, 2015 10:29 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
