Adjusting closed loop O2 AFR's
Old Nov 23, 2007 | 08:14 PM
91chevz71's Avatar
My closed loop O2 readings are going from 14.0 to about 15.5...I would like to tighten them up a bit. BLM numbers are good, 128 +/- about 5. Prop gains? I'm not sure how to tighten these up. Running EBL Flash, Zeitronix ZT-2 WB simulating NB O2.
THanks
Old Nov 24, 2007 | 12:24 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Re: Adjusting closed loop O2 AFR's
I don't know if this helps but I played around with the gains quite a bit. End result was that I gave up and went back to running the ECM off of the WBO2.
The problem I had was from NBO2 temperature changes. It varied so much that I was always changing the gains to correct for it.
How accurate is the NBO2 reading from the WBO2 sensor you are using? If I use the direct WBO2 reading for the closed loop (with code change) everything works great. The simulated NBO2 reading doesn't work that well.
Old Nov 24, 2007 | 01:24 AM
91chevz71's Avatar
my NB O2 was really weird...I even had a 3 wire and it still gave me issues. Since I bought the WB, I've been using it with consistent readings.
I just spliced the WB's output into the purple wire in the harness.
Old Nov 25, 2007 | 09:56 AM
91chevz71's Avatar
so, will reducing prop gains tighten up the AFR?
88SS6SPEED
Nov 11, 2015 07:05 AM
lakeffect2
Sep 7, 2015 03:52 PM
FireDemonSiC
Sep 3, 2015 12:31 PM
gixxer92
Sep 1, 2015 04:32 PM
CORV3TT3
Aug 23, 2015 11:26 AM
