Vortec 350 + LPE 74216 cam + HSR am I even close?
Old Nov 24, 2007 | 12:54 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
I've started the prom for my motor swap, the engine's getting done within a few weeks and I'm trying to rough up a prom to drive it home once it's installed. I'm using Tuner Pro and modifying a stock 1989 Firebird bin. So far I've taken the timing table and smoothed it out plus taken out alot of the cruise timing, it now looks like this;
33.75 35.16 35.16 35.16 35.16 35.16 35.16 31.99 28.83 24.96 23.20 23.20
25.31 34.10 34.10 34.10 34.10 35.86 31.99 27.77 24.26 23.91 22.50 22.50
25.31 34.10 34.10 34.10 34.10 35.86 32.70 27.77 25.31 21.80 20.39 20.39
25.31 33.75 34.10 34.10 34.10 35.86 31.99 26.72 24.26 21.80 20.04 20.04
22.50 33.40 35.86 35.86 35.86 35.86 33.05 27.77 23.20 21.09 20.39 20.39
22.50 33.40 35.86 35.86 35.86 35.86 35.16 27.77 24.26 20.04 20.04 20.04
22.50 33.40 35.86 35.86 35.86 35.86 35.16 28.83 26.02 24.26 22.15 22.15
22.50 33.40 35.86 35.86 35.86 35.86 34.45 32.70 28.83 24.26 22.15 22.15
22.50 33.40 35.86 35.86 35.86 34.81 33.40 29.88 26.02 24.26 22.15 22.15
22.50 33.40 35.86 35.86 35.16 34.45 32.70 26.02 23.20 22.15 22.15 22.15
21.09 29.88 35.51 34.45 33.75 33.05 29.88 26.02 23.20 22.15 22.15 22.15
20.04 26.02 30.94 30.94 30.94 28.48 23.91 22.15 22.15 20.04 20.04 20.04
18.98 23.91 28.13 27.77 27.07 24.96 22.15 22.15 22.15 20.04 20.04 20.04
17.93 21.09 24.61 24.61 26.02 25.66 22.85 22.85 22.85 20.04 20.04 20.04
15.47 15.47 15.47 15.47 15.47 17.93 20.04 21.09 22.15 20.74 20.74 20.74
16.17 16.17 16.17 16.17 16.88 18.28 20.04 20.74 20.74 20.04 20.04 20.04
17.93 17.93 17.93 17.93 17.93 18.98 20.39 21.80 20.74 20.04 20.04 20.04
I then went into the PE vs RPM and made it this to compensate for the fuel up high demands (starts at 600 goes down to 0).
21.87
21.87
25.78
25.00
24.21
21.87
20.31
25.78
32.03
23.43
14.84
16.40
13.28
3.90
3.90
3.12
3.12
*sorry if the timing table is confusing it looks like it overlaps*.
Is this going to be even close? I've never datalogged but I have the setup, I just want to be able to drive this thing before I really start having to tune it.
Old Nov 25, 2007 | 12:48 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Re: Vortec 350 + LPE 74216 cam + HSR am I even close?
I have a similar setup... Let me know how that is going for you. What is your FP set at and what is your inj. constant? I'll compare that /w my timing table when i get back to college later.
Old Nov 25, 2007 | 10:24 PM
Engine isn't installed yet, injector constant's are set at the stock 22, base angle is set at 6 but I think I'm going to bump that up to 10 in the prom and set it that way on the car. Fuel pressure will be stock, non adjustable regulator on the Stealth Ram. I'll keep you posted on what it actually does in the car.
Old Nov 27, 2007 | 08:43 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
From 3600-up in rpms, you can run 28* timing more than likely from 90-100 kpa...just make sure you run 93 octane. Now, for the idle, I would look in the 30-60 kpa cells and put those near 22-23 in 600 to 800 rpms. For the initial tune, set the idle to about 700 rpms.
Old Nov 28, 2007 | 07:17 AM
This is the $6e xdf and I'm using a stock MAF tune to begin with, how do the lV8 tables convert to the kpa tables? Initial idle is set to 750 as per Lingenfelters recommendation. It's rough finding stuff for these MAF computers, I'm still not sure where my LV8 is falling under WOT.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
bamaboy0323
Sep 3, 2015 06:07 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
