pin remover tool?
Old Jan 6, 2008 | 12:00 AM
???'s Avatar
pin remover tool?
when you guys repin the stock ecm's, what tool do you use to remove the pins without messing them up?
i need to switch some wires around in the ecm plugs and not sure where to get this.
thanks,
Old Jan 6, 2008 | 01:07 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: pin remover tool?
thanks,
Yeah, its called a jewlers screwdriver.
Old Jan 6, 2008 | 04:21 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
paper clip works too
Old Jan 6, 2008 | 08:59 PM
oldred95's Avatar
Or you can take an ordinary paper clip, unfold it and hit the end twice with a hammer and you have yourself a custom terminal removal tool. Put a J number on it and you've got yourself a 20 dollar Kent Moore tool.
Old Jan 6, 2008 | 09:21 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Precision flathead screwdriver is the easiest way. Just depress the tang in the middle while pressing the screwdriver back lightly and out comes the pin.
Also, if you mess one up, Motormite still makes them. Some autoparts stores stock the pins in the electronics/wiring isle.
Old Jan 6, 2008 | 09:39 PM
S105.7's Avatar
Car: '87 S10 Blazer & '91 RS
Engine: L98 & L03
Transmission: 700R4 & T5
Axle/Gears: 10 Bolt/3.73/3.42
nice pin remover Fast. i use the same one. works like a charm, but it takes some messing around to get the hang of pulling the pins.
Old Jan 7, 2008 | 11:33 PM
???'s Avatar
thanks guys, I thought it would be some kinda special tool
Old Jun 7, 2009 | 08:47 PM
fgcox1's Avatar
Reviving an old thread.
Are you guys going in through the center of a female pin to hit the release or on the outside of it?
Tnx Fred in Mesquite
Old Jun 7, 2009 | 08:50 PM
???'s Avatar
its the hole next to where the pin from the computer goes into it.
Old Jun 7, 2009 | 09:24 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
http://www.dynamicefi.com/RePinHowTo.php
RBob.
Hotrodboba400
Dec 10, 2019 07:07 PM
TheExaminer
Sep 6, 2015 11:40 PM
mrdevontay
Sep 2, 2015 08:04 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
RyanJB
Sep 2, 2015 01:27 PM
