02 what ??? bias
Old Jan 9, 2008 | 09:08 PM
carls1982z's Avatar
Car: 1982,Z/28
Engine: 355
Transmission: t350
02 what ??? bias
looking at diff bins and things i might try,, i see in tuner pro with my 7747 ecm that thier is a [02 idle afr bias value] [2f7]hex address. ---------can anyone give me info on this ?? as the bin im currently using has it at 109.00mv. and i see in alot of bins its at 0.00.
Old Jan 9, 2008 | 10:38 PM
91chevz71's Avatar
Re: 02 what ??? bias
sounds like just another bias that a lot of the stock calibrations have. just minus it from the O2 rich lean stuff to get the value used by the computer.
Like how the spark advance has a bias, the O2 has a bias
-edit
don't quote me on this, but I feel secure in saying that
Old Jan 10, 2008 | 08:08 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The value at $2f7 is added to the O2 window during idle. It is to make the idle richer from what is in the tables.
RBob.
Old Jan 15, 2008 | 07:12 PM
carls1982z's Avatar
Car: 1982,Z/28
Engine: 355
Transmission: t350
sounds like 91 chevy is saying it is taken away fuel,, and rbob is saying its adding ?? Im a little confused ??? here.-------------------- Im also trying to figure out if im better with my lean/rich/mean values at same settings thru out most air flows like alot of stock truck bins, or is it better to say have lean/rich values different ,, and mean as central point.------------read up on it here but its difficult to completely under stand.--------i was thinking that you would want lean/mean values diff,,,as to cause 02 switching ??and mean as the central point.-- or am i way off here
Old Jan 16, 2008 | 11:12 AM
91chevz71's Avatar
I would go with what RBob said.
Twilightoptics
Dec 22, 2005 06:03 PM
Casey_Butt
Jul 18, 2005 01:00 PM
Teeleton
Feb 24, 2005 04:35 PM
Low C1500
Apr 25, 2004 09:58 AM
JPrevost
Jun 14, 2002 06:29 AM
