Calibrating the o2 bias voltage for large overlap cam?
Car: 89 S10 Blazer
Engine: Built 4.3L V6 TBI
Transmission: Built 700R4
Axle/Gears: 7.65/Zexel/3.73
In my searches on the forum, I've read that a cam with lots of overlap will let unburnt oxygen through into the exhaust and skew the o2 sensor reading lean. The fix for this is supposedly to slide the oxygen sensor bias voltage down a little compensate, but how far? Right now if I let my blazer idle in the driveway long enough, the headers start to glow a dull red. Obviously, it's too lean, even though my cross counts and BLMs are dead on. Using the glowing headers seems a little inexact, and I really don't have access to an EGT setup. Is there any other good way to calibrate the o2 bias, or is EGT pretty much it?
Teeleton
Teeleton
Its not the leanness that makes them glow, though logic would make you thinkthat.. What makes the glow is the unburned fuel that comes out with the unburned oxygen.
The unburned fuel end ups burning in the header causing the glow. I would first try raising timing some at idle to see if that helps the situation, but it probably will not.
A great tool in aiding this is a hand held pyrometer, maybe a friend has one, or you can buy a craftman one for like $50.oo
and they are well worth it.
At idle you are want the surface of the header to be between
180-400 They will vary a little - like because the center feed off one another and 5 and 7 fire one after another.
But for your header to glow they are 500+ degrees. Mine were in excess of 600 at times and lowering the bias did not help enough, I had to run the car open loop which really did not bother me.
Another way to do this is lock BLM to like 132 or so, that way you can lean out at idle but the ECM will only try and compensate soo much, while not over ruling your command.
What happens is the unburned oxygen make o2 think you are lean-therefor it adds fuel, or you do because your BLM is high, that is much un needed causing it to burn in header.
Car: An Ol Buick
Engine: Vsick
Re: Calibrating the o2 bias voltage for large overlap cam?
Teeleton
Teeleton
It's EGT that makes them hot.
EGTs can be high, for reasons other then afterburning.
Car: 81 C10
Engine: L98 Hi Flow base+runners
Retarded ign. timing causes the mixture to complete its burn after the exhaust valve opens which may be contributing to the glowing header/manifold.
Car: 2000 BMW M5
3.8TransAM
Apr 20, 2005 01:35 AM
