PROM burning
Old Jan 26, 2008 | 11:05 AM
zupta82's Avatar
Car: 88 Trans Am
Engine: 305 TBI
Axle/Gears: 3:42 open diff
PROM burning
i am very new to eprom burning. I kind of don't know what to change when the information from the eprom is extracted with a programmer is this info called a bin file. after this what is next in line to do. I have ran winaldl and logged some data at idle and have downloaded tunerpro. As far as mods I have just a cam swap
oh by the way this is the cam. I have a 305 tbi motor
Chevrolet SB 1987-95 Hydraulic Roller Cam RV/Torque
Part Number: CS1079R
Manufacturer: Speed Pro
Pro 3000 Series Speed Pro RV/Torque hydraulic roller camshaft for Chevrolet SB 305-350 1987-95.
Specs are as follows: Advertised duration int/exh 273/288
Duration @.050 int/exh 198/210
Intake valve lift .433
Exhaust valve lift .462
Lobe seperation 112 degrees
Operating range 1200-4500 RPM with a smooth idle
Old Jan 26, 2008 | 02:37 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: PROM burning
For a SD system the first place to start is the VE table(s). These will change when a cam change is made. You can use the BLM data to update the VE tables with better values.
See the sticky Tuning Guide Book, there are a couple of articles on the TBI VE tables.
RBob.
Old Jan 26, 2008 | 05:01 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: PROM burning
after you have read the stickies RBob suggested, read this one if its not linked.
https://www.thirdgen.org/forums/tbi/...free-tune.html
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
dusterbd
Sep 29, 2015 08:40 AM
