TunerPro RT users. Need help determining injector on-time when data logging.
Old Feb 1, 2008 | 03:34 PM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
I'm using TunerPro RT for data logging. Everything is working fine.
The readouts give a value for injector pulse width. How do I know what the injector on-time percentage is? E.g. 80% duty cycle.
Old Feb 1, 2008 | 04:33 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: TunerPro RT users. Need help determining injector on-time when data logging.
You need to take RPM into account along with single & double fire (Note: this is for a MPFI setup). You can assume double fire for most of the time, then factor in the RPM.
RPM / 60 = RPSeconds
Then invert it for frequency. That gives the time available to fire the injector. Divide for the ratio of PW to Time and get DC%.
RBob.
KCG
Jun 24, 2020 04:33 AM
92-Formula
Dec 12, 2015 10:34 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
