Adding Air Pump Disable to XDF from $6E HAC
Old Feb 5, 2008 | 03:24 PM
86z28iroc-z's Avatar
Car: 86' Z28 Camaro
Engine: 357 TPI -- Dart Heads -- Voodoo Cam
Transmission: Built 700r4
Axle/Gears: 3.23 Posi
Interpreting HAC conversion values
I'm trying to disable the A.I.R. Pump and remove the 100 mv addition to the o2 but I'm having a hard time understanding how to go about doing this.
Can't find any informatioin on how to interperate the HAC information/calculations to add the items to the 6E.xdf.
The only link that makes some headroom is here https://www.thirdgen.org/forums/diy-...isable-6e.html
But they are using a different calc. than what the HAC says to use. How do you determine what the calc. means from the HAC.
Correct me if i'm wrong but what I've got so far is if the Hac says
LC324 FCB 73 ; 14c COOL, IF LT THRESH, DIVERT AIR
; Cal = (arg + 40) * 256/192
You add a Constant @ 324 and the calc you use is (X+40) * 256/192 I'm assuming that's for DEG F
Is that right?
Comes out to 151 Deg F
Any help would be appreciated!
Also I can't seem to find the place in the hac where it adds 100 mv to the o2 reading when diverting A.I.R
Thanks!
-Tyler
Old Feb 5, 2008 | 07:33 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: Adding Air Pump Disable to XDF from $6E HAC
At the bottom of this thread. Do a search on that text to find it.
Removing Smog pump, AIR: $8D 730 modifications
Old Feb 5, 2008 | 09:14 PM
Car: 86' Z28 Camaro
Thank, never read that one, didn't think it applied to the $6E. Clears up some of the info, but I still don't know how to interperate the HAC cal info.
If I plug that into the conversion it shows a value of 151, but using the other conversion of .75 * x + -40 gives the actual 14.75 Deg C value, converting 14.75 C to F shows 58.55 F
Any idea how that works?
Old Feb 6, 2008 | 09:15 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
You need to invert the equation. It is currently shown to go from deg C to the BIN value. To go from the BIN value to deg C:
BIN * .75 - 40 = deg C, the .75 from (192 / 256)
RBob.
scorp508
19
Aug 31, 2012 07:05 PM
Michelob
18
Sep 29, 2009 07:27 PM
Daveinet
Apr 13, 2009 12:06 AM
3.8TransAM
Apr 20, 2005 01:35 AM
