ebl running 4 saturated injectors
Old Feb 9, 2008 | 08:50 PM
liquidh8's Avatar
Car: 1981 Buick Century Wagon
Engine: 87 GN engine
Transmission: 2004R
ebl running 4bbl TB & 4 high impedence injectors
Hey all, was floating around the net today, and found a site selling a 4 barrel tb, that allows you to use 4 injectors. The smaller style like in the tpi and all. I was talking to the machinest in work, and we are going to attempt to use 2 stock GM tb's, take out the shafts & butterflies. I have a chnk off aluminum, and I am going to mill a 4 bbl tb out of it. I wanted to use 4 high impedence injectors with my EBL, but i don't have the driver upgrade done to it. According to RBobs site, www.dynamicefi.com, I can run 4 injectors no problem. Assuming I am reading it right. The next concern I have is do I make the front and rear butterflies open at the same time? Or try and make the progressive. BTW, I'l still be using an iac.
Here is a pic of the TB I found.
I'm not sure If I should make the injectors fire in on an angle like that, or make a halo type bracket and hang em from the top, like the stock tbi injectors. I thought I had seen injectors the fire at an anlge, instead of strait down, or maybe that was nos injectors.
I could just convert the intake to take 8 injectors, and use a 4bbl TB insted, but what fun is that? lol. Besides, I am turboing this car, I have one turbo, an aux injector plate, a piggyback ecm for the injectors, but the parts gathering is slow to come due to money, but I like the control the ebl has over the current n2o kit on the car, and the boost control features, as I won't be boosting this engine over 15 psi. (static cr is between 9.5 and 10:1 already)
What do you guys think??
Old Feb 10, 2008 | 02:25 PM
titchener's Avatar
Re: ebl running 4 saturated injectors
Your plan sounds doable, but I wouldn't use the stock TBI units butterflies and throttle shafts if you are trying to make this fit a standard Holley sized flange. The spacing is too far apart on the TBI butterflies for that. However if you are trying to make a Dominator sized unit then the stock ones would work.
I'm working on something similar but using the whole TBI units machined down to make a Dominator sized 4 barrel TBI for my drag engine, its a thread on here with "Franken 4 barrel TBI" in the title. I'm making pretty good progress on it and in a week or 2 I'll update it with some pictures and more info.
Paul T.
Old Feb 10, 2008 | 06:04 PM
liquidh8's Avatar
Transmission: 2004R
Paul, I have been following your thread. Been wating for some updates/pics. I never thought to check the spacing of the throttle bores to fit a standard holley flange. I make have a junk holley or 5 laying around (who doesn't?) I can steal the hardware from the baseplate and use it for this. I'd like to see your pics and progress as soon as you are done, keep us informed!
MustangBeater20
Oct 29, 2022 09:20 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
ezobens
Aug 19, 2015 10:29 PM
tmellott89
Aug 16, 2015 02:58 PM
