Wide Band O2 Sensor
Old Feb 13, 2008 | 08:07 PM
smithtc's Avatar
Wide Band O2 Sensor
I'm buying the APU1 and the GP1 pack for tuning my 89 GTA.
I was already "Planning" to buy an Autometer Wide Band Oxygen sensor guage for it. Is there a way to modify this to hook up to the APU1 or laptop? Or do I need to get something else?
Also...if I want to datalog AFR on more than 1 vehicle...what's the best way to go about this without buying a sensor and guage for multiple vehicles...or at least a different guage for every vehicle?
I've done searches and haven't found answers I'm looking for. I appreciate it.
I'm guessing I could buy an Innovative Motorsports for $350, and just a sensor and wire for each vehicle. Would the Innovative unit hook up to dataloggingsoftware that I'm buying from Moates?
Old Feb 14, 2008 | 08:48 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Wide Band O2 Sensor
One thing about WB sensors is that they can not be left in the exhaust of a vehicle being driven without being powered up. So you can't leave the sensor in a car without the controller connected & powered up if the car gets driven.
Typically folks will connect the WB output to a pin on the ECM and modify the ECM code. This puts the WB value into the ALDL data stream to be data logged.
The other method is to use the data logging capability of the WB unit and log the MAP & RPM along with the WB value.
RBob.
Old Feb 14, 2008 | 09:37 AM
AC's Avatar
AC
Car: Used to drive a camaro
I dont believe Moates freebie software has any WB02 functionality. Follow Rbobs advice and look into datalogging software that either comes with the WB02 (Innovatives comes with it) and research into how you can use your current ECM to interact with your proposed WB02.
Old Feb 14, 2008 | 01:37 PM
mk10842766's Avatar
RBob.
Don't mean to hijack your thread, but I have a quick question: do I connect a 0-5v source, or a 0-1v source if I use the hac? I'm assuming I can connect a 0-1V simulated NB directly in place of the nb sensor, on the same input wire as the nb sensor....
Thanx for letting me get this question in here...
Cheers,
Michael
Old Feb 14, 2008 | 02:17 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
If the ECM hac is to log the WB then it will be the 0-5 V output. This will also be a different pin then the NB input pin. For the standard NB input to the ECM it can only be the 0-1 V output.
RBob.
Old Feb 14, 2008 | 02:36 PM
mk10842766's Avatar
Thanx, RBob...that's what I thought, just wanted to check befor I hooked it all up.....
Cheers,
Michael
Old Mar 18, 2008 | 09:21 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
I was looking at the GM book for my 91 firebird 730 ecm & I saw 2 WB connections on the ecm.. one was WBlow, the other WBHi...
I'm planning on getting a wideband o2 also to use with code59...
Any one knows the differences between these inputs, or which I should use?
thanks,
Rafael
Old Mar 19, 2008 | 01:28 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
the 730 ECM can't use a wideband input.
the only Hi & low input i show is for the VSS.
which pins do you show to be listed as WBLow & WBHi?
i think it must be a misprint
Old Mar 19, 2008 | 06:20 AM
luvofjah's Avatar
My bad, it actually says oxygen sensor input hi (e14) lo (e15)... not wb... I'm just thinking ahead of my self... It is for a 91 730 ecm TPI.
What is the difference in these two inputs?
Again the code59 I will be using has code for a wbo2, just wondering which pin to hook it up to...
Raf
Old Mar 19, 2008 | 10:32 PM
DENN_SHAH's Avatar
E14 is the O2 sensor input, with the O2 sensor unhooked & the key on you should see around 0.450 volts on this terminal.
E15 is a ECM ground for the O2 sensor.
if you have a problem with E15, it can cause the O2 reading the ECM sees to be wrong. tapped into the O2 sensor wire with a DVOM, it may show, lets say 0.650 MV but the ECM could report in the data stream 0.400 MV. this can cause all kinds of problems with fuel delivery.
i've never messed with 59, i don't know. i would guess its for data logging the wideband in the data stream.
Old Mar 20, 2008 | 12:46 PM
luvofjah's Avatar
Yup, code is upgraded to work with wideband o2 and just takes the place of the stock 02 sensor...
Raf
9192camaro
16
Feb 3, 2019 12:21 AM
antman89iroc
36
Jan 31, 2016 08:42 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
doc
Feb 20, 2001 04:40 PM
