Help with finding BIN file
Car: 87 V10,94 C1500,89 vw fox,11 Camary
I have a 1987 chevy V10 with a 305. the pcm is a 7747 and the chip is ABHN. I can not find a bin file so i can burn chips on my truck.
Car: check
Engine: check
Transmission: check
Re: Help with finding BIN file
Take your curent chip and read that to start off. The other thing you can do is to find a BCC that is close to your setup and use that. Once you start tuning all that really matters is to use a stock BIN that is close to your setup.
RBob.
RBob.
I am unable to read the chip with tuner pro. i am about to give up and just buy your ebl flash.
Car: check
Engine: check
Transmission: check
Is this with a Burn1 or such? I don't believe that TP-RT is able to read BINs from just any burner. Most burners come with software to use with them.
I can't argue with that. It eliminates a lot of issues and the headaches that come with them.
RBob.
RBob.
It is an apu1 that came with the turner pro. I dont know what to set the chip addressing and buffering addressing.
Car: check
Engine: check
Transmission: check
This link has the info for offsets & such:
http://www.moates.net/documentation....entation_id=20
RBob.
RBob.
