Where are the trouble codes in Tuner Pro?
Old Aug 29, 2015 | 02:35 PM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
Hi there. I'm using 1227165-60.adx in RT 5. I can get data streaming through my Moates adl cable thingy and can successfully export into a .xdf file.
Thing is in list view there are very few data lists- 17 in total. But there are no fault codes listed at all?
Is it a case that it would list a code if I had one active? Not sure totally if I can modify it so it lists error codes etc. I have searched and searched but can't find the solution.
Please help a brother out.
Old Aug 30, 2015 | 01:48 PM
Vader's Avatar
Re: Where are the trouble codes in Tuner Pro?
I'm unsure on a 6E, but in a 32B the hex address range is $0005-$0008. TunerPro may not reveal the flags for these addresses in the item lists or item summary list, nor in the ALDL values in logging.
Old Aug 30, 2015 | 01:59 PM
Vader's Avatar
In 6E you can show at least Malfunction Word 1 in the data. Go to ALDL Setup, then select the ALDL Definition Editor. You can select the flags to be displayed in the data stream list. You may want to save the resultant ADS file as something different just in case it has errors.
Old Aug 30, 2015 | 02:39 PM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Hi Vader, I don't understand the hex address stuff. Will check it out, thanks for the replies
BumpaD82
Feb 26, 2016 02:57 PM
armybyrd
Dec 5, 2015 09:22 AM
Reese-J
Sep 14, 2015 02:43 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
85Special
Sep 3, 2015 04:21 PM
