PE % change to rpm
Old Mar 5, 2008 | 07:25 PM
tjvz28's Avatar
Car: 91 Camaro Z28
PE % change to rpm
in power encrichment all the #s mean more fuel being dumped in how do i caculate more this
how do i get to 12-7-1 afr
Old Mar 6, 2008 | 07:09 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: PE % change to rpm
As JP86SS posted in your other thread of the same subject:
"Tuning guide, chapter 5.
Will explain it well."
RBob.
Old Mar 6, 2008 | 11:49 PM
tjvz28's Avatar
Car: 91 Camaro Z28
i read ch. 5 and to figure my fuel ratio i want get
i converted to hex editor
how do i get these to decimal points so i can do the equations thanks
Old Mar 7, 2008 | 08:14 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
This equation?
WOT AFR = 6553.6 / (((TBL L8617 + TBL L860D + 128) * 445) / 256)
I'm not quite sure of what you are attempting. For the above equation 2 of the values come from tables in the calibration. It is just a matter of math after that.
To go from an desired AFR value to a table value the equation will need to be re-arranged. In this case if there is any decimal portion in the result round it to the nearest integer. This result needs to be within 0 to 255 for a value.
RBob.
eightsixseven
Dec 16, 2024 01:50 PM
jklein337
Sep 19, 2018 06:23 PM
86IROC112
Aug 21, 2015 07:20 PM
forstral
Aug 19, 2015 03:20 PM
