My RamJet 350 has 24# injectors and I was wondering if there would be a benefit to changing the value in the s_aujpv4 BIN from 22# to 24#?
I'll be adjusting the BIN for acquiring raw data from the LC-1 this upcoming weekend, so I thought I'd ask about the 22# vs 24# injectors at the same time.
yeah, if the ecm thinks its 22 lb injectors and you have 24's at the same pressures, the car will be injecting more fuel than it should be thus running rich
make the injector constants match what you have
