7427 Min/Max Sync/Async BPW???????
Old Mar 15, 2008 | 09:18 AM
Tbi-MAX's Avatar
crap im trying to tune my stuff, and ive been searching every single constant.. now im stuck at these...
my BPW i want it to be 96.18 (90# @ 15.1psi)
ohh yea its the 7427 pcm
the base .bin im editing is the bjym od.bin which i was told to start with.
Old Mar 15, 2008 | 09:24 AM
Tbi-MAX's Avatar
Re: 7427 Min/Max Sync/Async BPW???????
min async bpw is set to 503.54 usec
max async bpw is set to 11993.41 usec
async to sync bpw (min) is set to 701.90 usec
Old Mar 15, 2008 | 12:36 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Are you just trying to change the injector constant? Those are the injector PW thresholds for sync/async injector firings. Not what your looking for, I think.
You need to update the injector constant, which is at $4D88 and is stored as grams/second x 819.2. The injector contant is entered as grams/sec flow into the bin if your using tuner pro, so you will need to convert your PPH injector flow to grams/sec.
Old Mar 16, 2008 | 10:12 AM
Tbi-MAX's Avatar
yea thats what i was trying to do...
ontop of that i was using some modified OD_v1_02.xdf / i just switched to the OD.xdf looks much more towards my .bin file and pcm...
I got it all worked out, and the truck is totally better than b4. im still kicking myself in the butt from the late start, i should have done this much longer b4!
if you know where i can get a .xdf file with BBC IAC tables and tables for IAT please let me know ASAP! i would like them all in 1 .xdf file.. i have no idea if its such a thing.
Armored91Camaro
Aug 12, 2015 09:41 AM
BMmonteSS
Nov 12, 2003 07:26 PM
funstick
24
May 15, 2003 09:03 PM
V8Astro Captain
May 22, 2002 10:31 PM
JPrevost
Jan 12, 2002 06:25 PM
