TBI chip remover
Old Apr 11, 2008 | 09:30 PM
ggenovez's Avatar
TBI chip remover
Hi all,
Is there an easy way to separate the chip from the holder? I have a 1227747.
Thx
Old Apr 12, 2008 | 02:28 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: TBI chip remover
It really depends upon what piece you want to re-use. If I want the PROM I just cut the holder. If I want the holder I wreak the PROM getting it out (or at least end up with bent pins).
Some folks have luck squeezing the sides together to 'roll' the pins a little. Make it easier to get the PROM out.
Someone here posted that in order to re-use the holder and to make it easy to get the PROM in & out, he cuts the top pieces off of the holder. This is the two tabs and the little cross braces.
This makes it easy to push the PROM in and out from the top. When seating this into the socket need to push on the holder & PROM both.
RBob.
Old Apr 12, 2008 | 09:22 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The chip can be seperated from the holder without damage or deformation to either. Put the chip and holder upside down and push the chip down firmly into the holder and pull one side of the holder outward. This will release the pins on that side of the chip. Once the pins have been released, one side will pop up and you can pull out the chip.
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
NBrehm
Aug 25, 2015 11:49 PM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
