WILL NOT GO TO CLOSED LOOP PLEASE HELP
Old Apr 13, 2008 | 05:15 PM
tjvz28's Avatar
Car: 91 Camaro Z28
HELLO i have ecm 730 prom chip512 tunerpro rt having few problems i noticed datalogging
I started car ran went to closed loop for little bit then open agian. then i get ses light.no blinking just on o2 status says lean.
o2 reading are like .400 mv and when i was in closed loop the blms were way off. I know the o2 sensor wire is cut right a long block i need to run a new wire
I need to know why its not in closed loop is my chip wrong
would the o2 wire have somthing to do with this
Also i cannot record data log. everything else seems to be working
Old Apr 13, 2008 | 05:55 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Re: WILL NOT GO TO CLOSED LOOP PLEASE HELP
If the ECM can't adjust the fuel enough to get a good reading from the O2 sensor then closed loop cannot be maintained. The clue is that the BLM values are off. As I understand this, it means the ECM "thinks" that it isn't able to deliver enough fuel because the O2 sensor is indicating a lean condition continually. That is the symptom, so we need to know what the problem is. It could be the O2 sensor, or it could be a poor tune. If you're using the factory PROM setup, then it's probably just the sensor (provided you haven't switched from a 305 to a 350 or some such). Closed loop can't work without a valid O2 sensor output.
Old Apr 13, 2008 | 06:30 PM
tjvz28's Avatar
Car: 91 Camaro Z28
ok i have fixed o2 sensor it was grounding out
i still cant record anything
Old Apr 13, 2008 | 09:07 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Did you click on Tools->ALDL/Data Logging->Setup (or you can just press F4) and select a log file to be used? You have to create a log file before you can click on the red dot to record.
Old Apr 13, 2008 | 11:20 PM
tjvz28's Avatar
Car: 91 Camaro Z28
i got to record on my record in park i noticed o2 mv were all overthe place not constant like when in open loop could this be because im running way rich blms show 108
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Pac J
May 17, 2020 10:44 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
