s_aujpv4 OL idle? how to?
Old Apr 24, 2008 | 11:45 PM
RPOL98's Avatar
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
just wanted to be sure, to enable the open loop idle in s_aujpv4, is that the "IDLE Open Loop RPM Threshold (S_V4 only) OL Qual"? where you set the rpm at which below that, it goes OL?
thanks.
Old Apr 25, 2008 | 07:26 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: s_aujpv4 OL idle? how to?
If you idle at 800 RPM for example.
Set the lower threshold value to 900 (Location L8993)
Set the higher threshold to 1050 or 1100 RPM. (Location L8992)
OL idle will occur when you drop below the 900 RPM value and re-enter CL when rising above 1100 RPM.
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
