My USB to Autoprom cable failed....
Old May 24, 2008 | 09:26 AM
silvernblack's Avatar
Engine: RamJet 350 running EZ-EFI 2.0
Transmission: Richmond 6-speed
Axle/Gears: 4.1
Good thing I was just doing chip-burning inside(since it was too crappy to go outside)....so I'm having connection problems with both my old Win98 Laptop that I use to play in the car; and also in my new Vista Laptop which ALWAYS hooks up quickly. This seemed odd; booted and rebooted several times...still couldn't hook up to Autoprom. Struck me as odd that both computers would do this....I was hoping it wasn't the actual Autoprom; I had a couple more USB-to-Autoprom cables(dont' know what they're "officially" called).....swapped, tested the other 2, it's all good. I threw the original one away....I was kinda surprise; haven't really abused it, nor used it that much. I'm just glad it didn't happen when I was trying to play with the car. Anyway, something to check if you can't hook up to your Autoprom.
Old May 24, 2008 | 02:17 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Re: My USB to Autoprom cable failed....
By "USB to AutoProm cable" do you mean the USB cable? It's just a standard USB cable (the same kind used by just about every USB device with a full-size USB connector set). They have been known to go bad every now and then. Sometimes there are bad ones in a batch as well.
Glad you figured it out.
Old May 24, 2008 | 03:49 PM
Axle/Gears: 4.1
Yep, that's the one....I had a couple of extra ones that I've accumulated; a bit longer, but it latched right on. I woulda hated it if it was happening while I was trying to tune...it probably woulda sent me on a wild-goose chase.
Old May 24, 2008 | 05:21 PM
DM91RS's Avatar
Car: 91 RS
Being an admitted DA I would still think that now days you could convert serial to usb with out a hitch.......but that's just me.........
I still at times have problems with my generic unit when using my ebl data logging. On the other hand my Moates converter never let me down. I need to figure out how to hook it up somehow to the ebl unit...............lol
Have a great holiday weekend guys..........DM
Old May 24, 2008 | 08:03 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
i had a USB cable die on me at work. during the day i had made the changes to the bin & after work i got in my car & erased the chip, i did a blank check, then burned the chip. guess when the cable quit. it took me almost half a tank of gas to drive 15 miles in limp home.
now when im data logging & burning chips regularly i make sure to keep an extra cable in the car.
i also keep a good working chip in my car too
Old May 24, 2008 | 09:14 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Yep, that's what I do. Sometimes I will have two chips with two different bins.
Old May 25, 2008 | 01:59 PM
Axle/Gears: 4.1
good idea....
I just burned myself a couple of extra chips with the latest good tune...
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
tmellott89
Oct 14, 2015 02:06 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
