EBL tuning LO3+lt1cam+17psi FP
Old May 26, 2008 | 06:39 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
I need some help to learn how to tune. Thanks for any help.
I have recently installed a TPI fuel pump and set AFPR to 17psi (untill I get a better spring). DC% is now 90% at WOT 4400rpm. (stock it was 110%)
1. The car is probably running wery rich in Open Loop, it has little hesitations followed by little black clowds.
What should I do to reduce fuel in Open Loop?
2. SA main table. I have been reducing SA in the areas were I get retard.
Not sure about my smoothing skills, ... skills.
3. In Analysis I dont understand the 02 sensor.
Attached Thumbnails EBL tuning LO3+lt1cam+17psi FP-ts-ebl-29.dat-sa   EBL tuning LO3+lt1cam+17psi FP-ts-ebl-28.dat-skr   EBL tuning LO3+lt1cam+17psi FP-ts-ebl-28.dat-1
Old May 26, 2008 | 06:42 AM
thomas1976's Avatar
Car: 91 Trans am
Re: EBL tuning LO3+lt1cam+17psi FP
Attached Thumbnails EBL tuning LO3+lt1cam+17psi FP-ts-ebl-28.dat-2   EBL tuning LO3+lt1cam+17psi FP-ts-ebl-28.dat-3   EBL tuning LO3+lt1cam+17psi FP-ts-ebl-28.dat-4
Old May 26, 2008 | 08:31 AM
88Stepside's Avatar
Start by doing a few VE learns with EBL. Doesn't take long and will take care of fuel issues.
Are you using a WB?
Old May 26, 2008 | 09:28 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
With the higher fuel pressure the AE needs to be reduced. Can change it by the ratio of the increased fuel flow. If using 55 #/hr injectors (stock 305) then at 17 psi they will flow:
= 55 * sqrt(17 / 13) = 62.9 #/hr
55 / 62.9 = 0.87
Reduce the "AE - TPS PW" and the "AE - MAP PW" tables to the ratio 0.87. Can do this by highlighting all entries, toolbox, then multiply by 0.87. that will get the AE back into line.
The O2 sensor action is OK. In the -1 picture the O2 starts out cold. It's value is 451 mV. During the first throttle stab the O2 is getting some heat in it and is waking up. At 13 seconds the O2 starts to swing rich/lean.
In the -2 picture the O2 is alive and well and the engine is running in closed loop. The ECM forces the O2 to swing rich/lean while in closed loop. It is the job of the proportional gains to do this. this is done to keep the cat happy.
The picture -3 is interesting. Note that the O2 sensor voltage increases as the throttle is opened. Then falls off as the thottle is held open. This is a sign of too much AE. How much too much is difficult to say when observing a NB O2 sensor. Make the above change first, then see how it is.
The sudden jumps in RPM are most likely from either the TCC unlocking or the transmission downshifting.
RBob.
Old May 26, 2008 | 02:56 PM
thomas1976's Avatar
Car: 91 Trans am
Are you using a WB?
No im using NB stock 02.
Thanks Rbob, ill do everithing suggested and post the results.
Old May 27, 2008 | 12:43 AM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
EBL learns with the NB O2. It uses the BLM values.
Old May 27, 2008 | 04:36 AM
thomas1976's Avatar
Car: 91 Trans am
Yes, VE learn is a great help for someone like me, makes me wonder if I should do VE learns every thime I make little modifications in the SA main table or if I can skip a few.
"BPC-BPC vs VAC" table is set to 115, according to the Excell SS BPC table values for 17psi FP.
"AE->TPS%double MAP AE" is set to 100%
Old May 27, 2008 | 03:11 PM
thomas1976's Avatar
Car: 91 Trans am
Reducing AE had a good impact on open loop and idle. Thanks
Im not really happy about the DC 93%, definally need a stiffer FP spring.
Is the estimated FP for HP in the Excell at DC 100%?
02 still falls off at WOT, what can I do?
Attached Thumbnails EBL tuning LO3+lt1cam+17psi FP-ts-ebl-29.dat-1   EBL tuning LO3+lt1cam+17psi FP-ts-ebl-29.dat-2   EBL tuning LO3+lt1cam+17psi FP-ts-ebl-29.dat-3
Old May 27, 2008 | 03:42 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
You might try WOT Asynch, that will give you a slower, longer opening on the injectors at higher rpms delivering more fuel.
Old May 27, 2008 | 03:46 PM
thomas1976's Avatar
Car: 91 Trans am
If I only knew what that is... how do I set that up?
Old May 27, 2008 | 03:51 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
These settings will give you WOT Asynch above 3,000 rpm. These are the factory GM switch points for a 1995 TBI 350 Fullsize Van.
Old May 27, 2008 | 04:14 PM
thomas1976's Avatar
Car: 91 Trans am
INJ-High MAP to enter hig load async, 99.69 KPa
INJ-High MAP to exit hig load async, 99.69 KPa
INJ-High RPM to enter hig load async, 6375 rpm
INJ-High RPM to exit hig load async, 6375 rpm
I understand they are disabled.
So I can set to Async in the RPM and MAP range were DC% goes over 85% to get some more fuel... sounds good. Ill try that out thanks.
Old May 27, 2008 | 04:29 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It is at 85% DC and .45 BSFC
Consider a FPR that can be vacuum referenced. Works better when set up to vary fuel pressure to the intake manifold vacuum.
RBob.
Old Jun 2, 2008 | 05:23 AM
thomas1976's Avatar
Car: 91 Trans am
It turned out DC%89 @4400rpm with tose setting. Does that sound fair?
Old Jun 2, 2008 | 05:44 AM
thomas1976's Avatar
Car: 91 Trans am
I still get that figure, were should I start lowering AE?
RBob.
What VAFPR part# would be best? the ones I found all loock like year 12008 intergalactic turbochargers
Is there by chance a VAFPR that mounts at the stock location?
Old Jun 2, 2008 | 02:34 PM
Ronny's Avatar
AE is a juggleing act for sure. I would say make small changes to base EBL.bin and check the drivability. Today I pulled 61 usec globally out of my AE-TPS PW as I was seeing 9.5/1 on a fully heat soaked manifold. WB was not required as it was felt rich SOP. This is not a TPS movement to 100% but more of a reasonably sane but quick acceleration from 0-35. I will expect to see a difference. I probably have 66% of my AE in the TPS and remainder in the MAP. I do not have IAT control at this point in time. That is important for AE control as well. My manifold tends to run cold especially when cool environmental temps. AE seems just right when coolant hits 185deg then seems excessive after a 25 minute drive. I also made a small change in the filter values. Lower filter # increases the duration and volume. I increased the # so as to bring in AE sooner trying to overcome a lag. There is sooo much written on AE. "search".
Old Jun 4, 2008 | 04:37 AM
thomas1976's Avatar
Car: 91 Trans am
That a WB mesuring?
So micro changes at the time, is there a specific order or is AE-TPS PW the one I should start with?
Old Jun 4, 2008 | 09:56 AM
Ronny's Avatar
First off I run CL with NB02 active. I believe the best practice on a new unknown modified setup is to determine what fuel pressure is required for your engine to provide a safe A/F at WOT. Lets say that is 12.3/1 on the safe side. With that info in the BPC(fuel pressure required/inj size) one can then approach the easy steady cruise BLM and get that in line. That is easy with VE Learn. Along with that one can look at the open loop A/f ratio tables and be certain they match the observed A/F the WB is showing. I will say I am commanded OL to say 13.9/1 at 140-150F and observed is around 14.5. I trust the WB is 99% accurrate. I am OK with that as car is drivable at cold coolant temps. I cannot get a read on choke function nor crank function as WB is warming up. But the cold start is OK. Lastly is the AE routines and this is always problematic and frustrating at times. For me I have a cold manifold (Holley Projection TBI) with larger injs 80 lbs and a 7.4L TBI unit. That package is more difficult to get it right than mild mod to stock. I like to work lean to enrichment with AE. Lean pop then add AE till it is better. I have IAT setup but for reasons I cannot yet determine is is not functional! IAT would be quite beneficial on my intake. When I first started tuning I used Tunercat with a 7747 ECU. All I had to work with was AE MAP and AE TPS. Simple for a beginer. Also the tables were less in resolution. I did not have much to work with. with EBL and Tuner Pro I discovered expanded tables and more tables to fine tune AE. so much better. I discovered my AE was RPM sensitive. I was able to add AE at the lean(WB shows lean + audible pop) at one specific RPM. That worked well. Just added a visable gauge on the pillar column. Now I can see a lean condition in AE as it happens and B4 I needed to look at the logs and locate it. As far as where to DO the change maybe that comes with experience. A small change of TPS will be evident in logs. One can run down a level road at 20 MPH and do a series of tip in each one greater in TPS% and it appears in logs and should be smooth SOP. Issues are that AE quantity can vary based upon many variables such as manifold design and its temp, out side air temp, MPH at AE event, load on engine(MAP), RPM, transmission in use( me a manual)and TPS% change over set time. Look at stock GM table(s). I tried to work off that with global changes. That did not quite work. Past week I added AE at the lower TPS%s and pulled some on the % above 25. I also added AE MAP globally about 10% as on a slow gradual TPS increase from say 10% to 75% I saw the MAP increase signficantly and gauge went to 20/1 amd lean bog(heat soaked again). I added VAFPR so had to redo all two weeks ago!
Maybe more than you wanted to read.
Old Jun 5, 2008 | 06:40 AM
thomas1976's Avatar
Car: 91 Trans am
Thanks Ronny, Im still studing your reply
Old Jun 26, 2008 | 05:27 PM
thomas1976's Avatar
Car: 91 Trans am
Reducing SA due to some spark knock retard, my table ended in a mess.
I started over with the EBL_F_0016.bin (stock federal 89-92 tbi tg)with the appropriat FP settings and Hiwy mode desactivated, it runs incredibly nice.
Did some VE learns and lowered SA in the 95-100kpa/4000rpm-up area, were I had 1-3° knock retard.
Also installed a 3wire heated 02 sensor, since I had to stomp it so much to wake the stock one.
Old Jul 2, 2008 | 09:23 AM
thomas1976's Avatar
Car: 91 Trans am
55 / 62.9 = 0.87
Ok, im preparing to bump FP to 20psi if the new spring will allow it.
Is this right?
55 * sqrt(20/13) = 68,219 #/hr
55/68.219 = 0.81
I also read somewere Hiwy mode must be off by VE learning, is this still the case?
Old Jul 2, 2008 | 09:44 AM
Ronny's Avatar
I believe so. Same on charcoal canister purge(disconnected) and I believe EGR.
edit: possibly deaccelleration enleanment too.
Old Jul 2, 2008 | 12:11 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Is this right?
55/68.219 = 0.81
Your fuel calc looks good.
For VE Learns, the highway mode doesn't have to be off. It will stop learning whenever it is active. So you get better coverage with hiway mode disabled. I usually set the min MPH to 254 to disable it.
The CCP line to the TB should be pulled and the TB capped.
The EGR should be disabled in the calibration. Can do this by setting the enable temperature high.
Then once VE Learning is completed, re-enable the EGR and tune that in.
CCP can then be re-connected, no tuning required.
There is a section in the WhatsUp.html doc on setting up VE Learns.
RBob.
Old Jul 5, 2008 | 10:51 AM
thomas1976's Avatar
Car: 91 Trans am
I ended setting 21psi FP and did around 3 hours of VE learn in 5-6 times.
It gives DC% 81 around 4400rpm.
The new heated 02 sensor shows 900-1000mv most times by WOT and falls wery little, I will reduce AE TPS a litte like Ronny suggested.
What tuning has to be done to EGR?
Thanks alot guy's.
Old Jul 5, 2008 | 01:10 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
EGR is easy to tune in. Enable it and do some VE Learns. However, do not use the new BIN. Just look at the corrections and change the "EGR - BPC Multiplier vs VAC" table for the least amount of corrections. It won't be perfect as the EGR flow moves around.
You can then play with the "EGR - SA added" value. Want to get the lost power back, but not so much that the engine doesn't like it. Be reasonable with the amount of SA added when EGR is active.
RBob.
Old Jul 7, 2008 | 04:22 AM
thomas1976's Avatar
Car: 91 Trans am
If the learned VE kpa/rpm number is higher that before do I need to increase or lower the "EGR - BPC Multiplier vs VAC" multiplier?
Only the final "EGR - BPC Multiplier vs VAC" multipliers need to be used in the new bin I have already done VE learns to?
Old Jul 7, 2008 | 08:50 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
If the VE Correction% is greater then 0 then increase the "EGR - BPC Multiplier vs VAC" multiplier.
Correct, it is the only table that needs to be changed to get the BLMs close to 128 again.
RBob.
Old Jul 7, 2008 | 03:30 PM
thomas1976's Avatar
Car: 91 Trans am
Im lost. Could you please make me an exemple on how "EGR - BPC Multiplier vs VAC" multiplier needs to be increased or lowered comparing these 2 VE tables?
Attached Thumbnails EBL tuning LO3+lt1cam+17psi FP-ebl-f-ts-0018   EBL tuning LO3+lt1cam+17psi FP-ebl-f-ts-0018
Old Jul 7, 2008 | 08:57 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
When at the VE Learn display click the radio button for 'Corectns' (short for Corrections). At the top of the display it will state 'Corrections in Percent.'
From that you can see the percent of correction at various points. Use the baro pressure and the MAP (from the display) to see the vacuum that needs to be changed for an active EGR.
RBob.
Old Jul 8, 2008 | 05:19 AM
thomas1976's Avatar
Car: 91 Trans am
havent realized tose 3 buttons
Were can I see the baro pressure?
Attached Thumbnails EBL tuning LO3+lt1cam+17psi FP-ve-learn-corectns-1
Old Jul 8, 2008 | 07:09 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
For baro can key-on, engine-off. It will be whatever the MAP KPa reading is. Best to use the Diag display for this reading. The other place is to do a Dump Log from the analysis display. It is the column labeled 'BRO'.
RBob.
Old Jul 11, 2008 | 07:50 PM
thomas1976's Avatar
Car: 91 Trans am
I set fueling in the copy of stock federal bin and dit 4 VE learns.
Based on the VE corrections, wery similar to te one attached abowe I did the following
KPA, changed%
60 -1
55 +1
50 +1
45 +2
40 +1
35 +1
30 +1
25 +1
20 = (no modification)
15 =
10 =
5 -1 (smooted it in the 10kpa %)
0 -2 (key-on engine-off, diagram shows KPa 98.04)
and adjusted "EGR - BPC Multiplier vs VAC", in the "EBL-f-ts-0018" bin I already made 3hours of VE learn.
Is this the right way? Im really sorry but this is the most unclear thing for me untill now.
BLM goes rather over 128 then under, also get some single knock retard under medium accelleration in 1 of 4 acclerations and I noticed that even thought the engine is hot the closed loop flag turns off many times.
-I though of reducing "closed loop-02window timeout" from 20 to 10 seconds to stay in more in closed loop.
The weather was really cool and rainy today vs the wery hot day I did the 3h VE learn.
-Since my air intake is drowing cooler air then stock and themperature does dropp relatively fast as speed increases I thought of reducing "IAT/CTS-blend filter of 1/4 and see how it reacts.
Old Jul 14, 2008 | 08:04 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Changes seem to be OK, nothing major which I would expect. The slight knock retard with the hotter weather is also normal. These engines are so knock sensitive that reducing the timing to eliminate it also kills the power and mileage (kilometer-age?).
For dropping out of closed loop, best to check why it is doing it first. It may be from open loop decel or highway mode. If it is from limited O2 swing those values can be changed a little.
RBob.
Old Jul 16, 2008 | 02:07 PM
thomas1976's Avatar
Car: 91 Trans am
21psi is giving me DC%85 @4500, assinc is desactivated but it lights up on the WUP display some times
For the SA I thougt of adding a little in the 70kpa up area, were does it make sens to start adding?
From loocking at the datalogs, it is dropping out of closed loop wenn lifting the foot of the gas.
"hiwy-in time" is set to 0, I found strange that it stays in hiwy mode for 240sec. after floring it during a cruse.
02 is swingin higher and lower than stock.
How is the open loop decel called? whanted to try that one but coouldent find it.
Rocket-Doc
Nov 14, 2015 02:08 PM
