Secondary cooling fan
Old May 28, 2008 | 04:24 PM
ULTM8Z's Avatar
Wanted to get confirmation on something…
Pin D12 controls the secondary cooling fan? The schematic I have shows that the secondary cooing fan relay is switched by a stand-alone coolant temperature temperature switch and/or a secondary cooling fan request pin on the ECM- pin D12. My Painless harness isn't populated at D12 so I was going to add it in.
What I'm going to be doing is adding a two-speed Ford Taurus fan and I wanted ECM control of both speeds. The $8D code has on/off temps for a second fan and my schematic (from gmecm) has it shown as a valid I/O on the ECM.
Can anyone please confirm this?
Old May 28, 2008 | 07:35 PM
ULTM8Z's Avatar
Re: Secondary cooling fan
Hmmm... there may be a misprint on the gmecm schematic.
I just looked at my ECM harness and D12 is pre-populated with ground wire (black w/ white stripe)
I also got hold of a Haynes manual and it shows D2 as the secondary fan I/O. I guess I'll just have to put a temperature in the calibration and then hook up a test light to the terminal to see if that pin turns the light on.
Old May 28, 2008 | 08:07 PM
ULTM8Z's Avatar
Didn't work. So it looks like both D2 and D12 are not correct. Anyone have any ideas??
Old May 28, 2008 | 11:09 PM
ULTM8Z's Avatar
Nevermind. I think I just found my answer on a search.
Old May 28, 2008 | 11:19 PM
w/t1500's Avatar
Car: 93 W/T1500
Engine: 350 Vortec TPI
Transmission: 4L60e 2000 stall
Axle/Gears: 3.08
7730 pin-out
W/T1500
File Type: zip
Old May 29, 2008 | 01:50 PM
ULTM8Z's Avatar
Awesome! Thanks.
Old May 29, 2008 | 02:28 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Trying to find info for the 165 and 6E to go
both fans controlled by ECM
Any help??
Old May 29, 2008 | 02:52 PM
ULTM8Z's Avatar
I think I saw something on the $6E in my search. I was more interested in the $8D, so I didn't really read it carefully. But I do remember the $6E being brought up
I searched on "secondary fan" and a bunch of good stuff came up. Give it a shot!
Old May 29, 2008 | 03:13 PM
jaykar's Avatar
Already did, but will give it another shot
Had seen something about a year ago on this board
but was not a priority at the time.
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
