Need help with some basic MEMCAL understanding
Old Jun 5, 2008 | 05:15 PM
R3500's Avatar
edit
Old Jun 5, 2008 | 08:13 PM
Pop45398's Avatar
Car: '91 RS
Engine: 355 on a stand
Axle/Gears: 3:42
Re: Need help with some basic MEMCAL understanding
If you want to have knock retard control you will either have to use an external ESC module (which you may already have) or get a different MEMCAL that has the ESC module built on to it (above the two smaller chips). Note that the two types (internal/external) use different knock sensors.
If you want to have limp home mode capability that runs half-way decent, and your engine isn't too far off from a stock motor, you will need a new MEMCAL for your particular engine. If you can do without limp home mode (or one that runs half-way decent), you can either disable code 51 in your PROM (if the mask you are running checks for cylinder select like $8D does--if not you don't need to worry about it) or you can modify your MEMCAL for 8 cylinder by jumpering pin 62 to pin 56 (pins 8 and 11 on the 14 pin chip).
Old Jun 6, 2008 | 08:01 AM
R3500's Avatar
edit
Old Jun 6, 2008 | 11:24 AM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
give House of Camaro a call @ (818) 700-7970, and ask for Tom. they specialize in Camaro and Trans Am used and salvage parts
Old Jun 6, 2008 | 05:54 PM
R3500's Avatar
edit
InfernalVortex
Apr 20, 2021 11:31 AM
loud91rs
Oct 5, 2015 10:05 PM
hartsmike
Oct 2, 2015 07:11 AM
Luigytico09
Oct 1, 2015 08:46 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
