ebl woes
Old Jun 8, 2008 | 01:48 AM
Colts45s's Avatar
Car: 92 camaro rs
Engine: 350 tbi/416's/comp xe268
ebl woes
having problems with getting a ve learn after my header install. included is a log i ran and i followed the steps to do a learn as per directions and as how it has worked before. any ideas just doesn't seem right. and exhaust shop did crappy job so i assume where all the knocks are.
File Type: zip
Old Jun 8, 2008 | 09:06 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: ebl woes
The ECM isn't going into closed loop. Which is why no learning is taking place. The O2 sensor is only getting moderately hot, with it barely hitting 700 mV's at times. The O2 never goes low enough or high enough for the ECM to believe that it is ready.
With the O2 relocated further from the heads a heated sensor is required.
RBob.
Old Jun 8, 2008 | 12:26 PM
Colts45s's Avatar
Car: 92 camaro rs
Re: ebl woes
ugh lol thanx for he speedy reply will hook up a three wire and see.
antman89iroc
36
Jan 31, 2016 08:42 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
Quzyle
Oct 15, 2015 03:35 PM
92rsvortec350
Sep 16, 2015 09:12 AM
85Special
Sep 3, 2015 04:21 PM
