Innovate LM-1 datalogging?
Old Jun 8, 2008 | 08:08 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
As I don't have the conversion box am looking to log the WB output (0-5V) from the LM-1 into the 165 ECM so I can datalog with Datamaster.
Can I use the fuel pump volts input?
Does this input to ECM perform any function?
Where does the ECM check the voltage to do the injector pulse width correction v batt voltage; just from the main power feed?
Q?
As the LM-1 has a simulated NB output you can use to run ECM in place of stock O2 , does this output have the same range accuracy as the WB it is fed off?
Old Jun 8, 2008 | 01:11 PM
JackL's Avatar
Re: Innovate LM-1 datalogging?
Excellent question I have been wondering myself.
ULTM8Z
Oct 2, 2015 01:25 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
ezobens
Aug 19, 2015 10:29 PM
bamaboy0323
Aug 15, 2015 07:20 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
