winaldl setting ???
Old Jun 16, 2008 | 08:48 AM
carls1982z's Avatar
Car: 1982,Z/28
Engine: 355
Transmission: t350
winaldl setting ???
Having problems with winaldl.----If i log BLM at a certain map, lets say 30, and then save. ---- I then open it up to see what i need to adjust,[BLM] and it will says its at 20 map ???? --What do i do to correct ? - adj within winaldl ?? ----help
Old Jun 16, 2008 | 01:37 PM
carls1982z's Avatar
Car: 1982,Z/28
Engine: 355
Transmission: t350
Re: winaldl setting ???
No idea guys ?????
Old Jun 16, 2008 | 02:06 PM
Ronny's Avatar
Carl, It has been a while since I used that program but winALDL is a log of current BLM vs RPM/MAP from what i recall. As well as a display of current readings from sensors. I would see say 140 BLM at 2400 rpm/30 MAP. Then I did the calc of adding fuel 140/128 X the fuel value in my lower (1) VE tables and upper table (2). That was done in my editing .bin program(Tunercat). My apologies if winALDL has changed its program to log a specific MAP (ie 30). Please explain further.
Old Jun 16, 2008 | 02:58 PM
drowning in tbi's Avatar
I don't have my tuning computer with me but... I have to remove a blank space BEFORE and AFTER the forward slash ( / ) on the line that has the MAP values, then the value and the column lines up correctly. If I understand what you are asking.
Old Jun 16, 2008 | 09:17 PM
carls1982z's Avatar
Car: 1982,Z/28
Engine: 355
Transmission: t350
Ill give that a try, ---And i also see mine has a backwards slash.--- ill let you know how i make out.
Old Jun 17, 2008 | 08:42 AM
carls1982z's Avatar
Car: 1982,Z/28
Engine: 355
Transmission: t350
changing that slash in my saved log fixed it.. --- But isnt there a setting so you wouldnt have to change it every time you re log,, and open it back up to check ??? --- Also on main screen of winaldl it has bacwards slash ? seems there should be adjustment
Old Jun 17, 2008 | 01:29 PM
carls1982z's Avatar
Car: 1982,Z/28
Engine: 355
Transmission: t350
Hope theres a setting to my last question
82tabird
Dec 21, 2015 10:22 PM
lt1z350
Sep 29, 2015 01:50 PM
hydrolic144
Aug 29, 2015 04:14 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Aug 24, 2015 06:52 AM
mustangdmurder
Aug 21, 2015 07:17 PM
