Off idle stumble you say??
Old Jun 17, 2008 | 10:25 AM
ULTM8Z's Avatar
So you say you have an off idle stumble?
Before you assume your AE needs tweaking, check to make sure your closed throttle SA matches the SA at the MAP you're idling at!
Case in point, I was doing some modifications to my calibration and after a few iterations I started noticing an off idle stumble. So, I started playing around with the AE for another few iterations and couldn't get rid of the stumble. So of course I did some more iterations and still couldn't get rid of it! It finally occurred to me that I adjusted the SA in the main table without adjusting the closed throttle SA. Ended up with a difference of 4 deg. So I went back to the calibration before I started messing with the AE, correct the SA advance descrepancy and bingo, stumble gone. Apparently that 4° was enough to cause a stumble on the off-idle transition.
So there's my tip of the day.
Old Jun 20, 2008 | 09:48 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Re: Off idle stumble you say??
Excellent! I think I've found an answer to one of my problems....
THANKS!!!
Grant2k
Apr 4, 2016 08:21 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
earlpote
Sep 12, 2015 11:55 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
