question on s-aujp
question on s-aujp
ok so this will be my first attempt with proms, have a 305 speed density, i want to run the super aujp do i need to do any other mod to it? also what definition should i start with?(i should be able to figure out how to upload them once i get my burner going with the moates emulator/burner/datalogger combo) ive tryed searching but dint seem to find exactly what im looking for
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: question on s-aujp
You need to change the engine displacement and injector constant to match your setup.
Keep an eye on the knock counts when you first run it to be sure there is not too much timing for your motor. Some like it, some don't.
Use the V4 41026 version so your up to date on everything.
See here for the revision notes and change needed:
https://www.thirdgen.org/forums/diy-...4-1024-vs.html
There is an error in the XDf that comes with it. You must make the change yourself.
Select the item, hit F2, change the address and save. that easy.
Please report back your experience with it. Feedback is essential to progress.
File is here:
http://www.moates.net/files/2)%20Cus...JP_V4_1026.zip
Additional info is here on the 730's extra inputs and such are included.
Hopefully the link will work and take you right there.
Jp
File is here:
Jp
