Correct/Most accurate ADX for 87 $32b in corvette?
Old Jul 1, 2008 | 10:48 AM
-=Jeff=-'s Avatar
Car: 1990 Corvette ZR-1
Engine: LT5
Transmission: ZF6
Which is the best ADX file to use in tunerpro to scan a 1987 Corvette??
I am help a friend learn how to scan his car so we can tune it. he is in Florida with the car I am in Illinois, so I will be looking at the scan to see what is what etc, then either changing things are having him change things.
I wanted to get the best ADX file for him so when we scan we can be comfortable saying that the scan is accurate. I want to be sure that the column headers match the right columns of data etc.
Old Jul 3, 2008 | 09:05 PM
raidmagic's Avatar
Re: Correct/Most accurate ADX for 87 $32b in corvette?
Bump, I'm the guy in Florida.
Old Jul 4, 2008 | 01:12 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
I'd switch from 32B to 6E with more options.
Could use the ARAP bin since running Aluminum heads.
Might have to take out a little timing with it.
Later
Old Jul 14, 2008 | 07:15 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Since he is running all analog gauges anyhow, why not swap to a '730?
Looks like he's ditching the blower too.
Speaking of which, what the heck are you building!?
-- Joe
Old Jul 16, 2008 | 09:04 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
With Tuner Pro (and maybe Tuner) you can add, delete, change, and reposition the data lines to anything you want. Just edit and "save as" a new file. I run different ADX files when tuning a different data area.
tmellott89
Oct 14, 2015 02:06 PM
ULTM8Z
Oct 2, 2015 01:25 PM
the_hamturdler
Sep 30, 2015 12:50 PM
dusterbd
Sep 29, 2015 08:40 AM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
