Minimum Injector PW
Old Aug 5, 2008 | 11:01 AM
TMO's Avatar
TMO
Engine: 350 TBI
Minimum Injector PW
Does anyone know what the minimum injector PW is for a TBI?
I am running a slighlty modified 350 TBI and my DC is hitting 96% on WOT. I am currently running 71# and at idle my PW is 1.3 msec. I have the WB installed and need to do some runs with it to see what is going on. PE is at 12.8, but I am tuning to 14.7 and need to change this to reflect 10% ethanol.
I am hoping I can bump up the pressure without running into idle problems. This question is a bit premature until I do that, but I want to think through the problems before I venture further. I am hoping I can avoid complications such as running a VAFPR.
Old Aug 5, 2008 | 11:12 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Re: Minimum Injector PW
It depends on the ECM. Some ECMs don't report the actual BPW sent to the injector. Does the PW you posted include open/close time and batt. correction?
Old Aug 5, 2008 | 11:15 AM
TMO's Avatar
TMO
Engine: 350 TBI
I am using the EBL which provides all these. Using 7747.
Old Aug 5, 2008 | 11:30 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Since the EBL is "copyrighted" then I can't comment on it. You need to talk to the vendor to find out what BPW it reports. If you were using a GM ECM with open code I could help.
Old Aug 5, 2008 | 01:24 PM
Ronny's Avatar
Are you aware you can run OL at idle. That would allow a richer A/F idle(place in tables). also run "synch" only(disallow asynch entirely) which too will help idle quality.
Old Aug 5, 2008 | 06:44 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
TBI injectors run as low as 600 - 900 usec's (.6 - .9 msec) before they stop delivering fuel. Depends upon the inejctor size and fuel pressure. The reported sPW is as what is found at the injector.
RBob.
Old Aug 8, 2008 | 07:12 PM
TMO's Avatar
TMO
Engine: 350 TBI
Thanks RBob - you are the best
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
