BLM's changing at idle.
What could possible be wrong.
Im used to se my BLMs change a bit during idle. But now its crazy.
My BLM's are changing between 118 and 150 during idle. It climbs up and down..
No vaccume leaks that I could find. And the trend is the same no matter what i put in the VE tabel.
The only thing I changed on the car, is that I put on the stock CAT, and installed a hayfire ign box.
Missfire, bad 02 ?
Tomorrow I will pull the plugs.
Any ides?
Missfire, bad 02 ?
Any ides?
Car: 1983 G20 Chevy
Transmission: 4L60
Re: BLM's changing at idle.
Missfire, bad 02 ?
Any ides?
Missfire, bad 02 ?
Any ides?
Car: 1989 IROC-Z
Transmission: Th700R4
Is the car in closed or open loop when this happens.
When did you change your o2 sensor last time ?
The o2 sensor shall be changed every ~45000km
If the car is in Closed Loop it shall be on 128 (+/-)3 in BLM (L-term) and INT (S-term)..
Hows your injectors ? How do the car run ?
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Hi A. had a nice vacation?
O2 changing- NBO2 varies some depending on temp. I logged the EGT compared to NBO2 and WBO2 and you could see it very clear.
Air leak? How close the the collector gasket is the O2?
Missfire can caurse any sort of problems, I know
but you should here it miss? Pull the plugs, if you like you can email me a logg file and spark plug pictures, I have done a lot of reading about sparkplug reading this summer.
/N.
did you sort out your other problem? was it stall saver?
but you should here it miss? Pull the plugs, if you like you can email me a logg file and spark plug pictures, I have done a lot of reading about sparkplug reading this summer./N.
I use a heated 02 at the collector of my hooker headers. The 02 is only 2 year old with 1242 miles on it.
Right now the cars idle is stabel, and I can hear no missfire. But I can feel it not running smooth during slow, low rpm driving.
Something is not right. I will com back after pulling the plugs.
THanks
THanks
Update.
Plugs look ok, a bit on the rich side.
I noticed a trend. When the car is cold the idle is fine.
Then when the car enter closed loop the first time , the BLMs are dead on. But as temp rise so does the BLM. And the engines idle get worse and worse.
I can smell gas so im definitely NOT lean. Its the other way around.
And it doesnt matter what i put in the VE tabel. So this must be something mechanical. I took of the cat and replaced that with a strait pipe. But no change.
Also I noticed that the car gets in and out from closed loop. It never did that before, as I use a heated 02. And I have verified that I have 12v at the censor.
My bet is a bad 02 censor,that shows "ok" value when warm. But the hotter it gets, the more error it shows.
What do you think?
And can i use any kind if 3 wire 02, or does it have to be a ac delco?
just a notice. The car does not consume any coolant. Or get hot to fast etc.
What do you think?
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
They are not very expensive so its worth a shot.
I have used AFS-74 and some OEM market from "hansen racing" and they worked good. I have heard bad things about "biltemas"
/N.
/N.
Car: 1989 IROC-Z
If youre way rich that will kill the o2 sensor to...
I would put my money on a new o2 and go from there, you got a heated 2 from www.tpiparts.net fast shipping and most times you dont have to pay customs and taxes..
