Can closed loop ever run as good as open loop ?
Old Aug 21, 2008 | 05:04 PM
jmesser's Avatar
The reason I ask is my 92 k1500 ( 5.7 with bolt ons ) runs so strong in the low to mid RPM ransge when cold but so so when warmed up in closed loop.
I can post some log files ......
Joe
Old Aug 21, 2008 | 08:24 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Re: Can closed loop ever run as good as open loop ?
It is the other way around. Closed loop is better than open loop. It sounds like your closed loop parameters need some tuning.
Old Aug 22, 2008 | 02:35 PM
Ronny's Avatar
yup OL enrichment is compensating for need for better tune. When you say strong that suggests AE event with OL mode. You may see benefits from a datalog and see what you need to consider changing in fueling tables. I found that to be my case on my first tune. Fatten up the VE tables and work from rich to lean on BLMs. That gave me faster results. Take it easy on pedal till you have a handle on where you are.
Old Aug 23, 2008 | 07:31 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Easy way to tell is data log at the same steady speed. Watch how much difference there is between open loop injector ms and closed loop ms.
My guess is you are a lot richer in open loop then in closed.
customblackbird
Aug 15, 2021 10:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
mustangman65_79
Aug 11, 2015 03:17 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
