trying to tune have datalogs
Car: 92 Camaro RS
Engine: 3.4/3500 hybrid
Transmission: 5-speed
I'm new to tuning and have a 11.5 compression v6, 272 cam,headers,70mm tb, 24lb ford injectors,went to dis, and 3500 alum. heads. The car was way out of tune but have it where it runs it open loop, but when in closed loop it will die when it gets down to about 1200 rpms. I haven't driven it yet due to it being hard to turn over after it warms up and I hate to get away from the house and it die. Any help with the tune will be greatly appreated.Would also like to drive it again. Here is two datalogs, (I tried to get the bin, and the xdf but it kept saying invalid file) if anyone would like to see if they know whats going on.
Car: 92 Camaro RS
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: trying to tune have datalogs
Are you using the stock spark tables? I would start by copying the sp. tables & other stuff from a v6 cavalier (have it if you need it) and starting there. Should be a closer match to the 3500 heads you have.
Car: 92 Camaro RS
I have a fwd bin I would attach it but it says invalid file, I just got a free trial of excell, what settings do you use in excel to keep it from running everything together and put them in columns?
Car: check
Engine: check
Transmission: check
When opening the text file use: Delimited->Next->Comma
Then once opened in Excel, click on the first data row, then: Window->Split
RBob.
RBob.
Car: 92 Camaro RS
thanks, I have them in columns now. Now I just need to search and see what I need to get them at.
