7730 syclone bin Tunnerpro-RT ostrich 2.0 what am i doing wrong
i am having a h*ll of a time loading my syclone bin file onto my ostrich it says no xdf file and every time i ^ upload to emulator it says sucsesfull but when i verifi its a no go ?????? confussed
Transmission: 5-speed/T-5
Re: 7730 syclone bin Tunnerpro-RT ostrich 2.0 what am i doing wrong
Are you loading an xdf file? I don't think I've ever seen an error that says "no xdf". I've seen a "Mismatched xdf and ads" error though.
Do you have "checksum disabled by upload"? If you do the verify WILL fail. Checksum does need to be disabled to to emulate, otherwise a prom error will pop up once a change or two is made.
Car: Used to drive a camaro
Make sure you grab the latest xdf file available on code59.org Check back after you confim thats the file you're using. I'm using the same setup, 730ecm, $59 bin, Tunerpro RT and an Ostrich 2. My car runs great.
It sounds like he's using $58, by the "syclone bin" part.
a $59 xdf won't work properly with a $58 bin.
a $59 xdf won't work properly with a $58 bin. Re: 7730 syclone bin Tunnerpro-RT ostrich 2.0 what am i doing wrong
ok got the thing to verifi quick question about aldl. do i need the 7730 aldl or the $58 aldl?????
$58 ALDL def. The ALDL data and scheduling is done in the chip (bin) not the ECM.
