Raising Idle While In Drive?
Car: 86 IROC-Z
Engine: 370 LQ9
Transmission: T56 Magnum
I'm having some problems with a 92 L98 Camaro stalling out sometimes because the idle gets to low. Is there any way to tune a chip with Tuner Pro; so I can raise the idle in drive? If so could you explain it to me, as I have no experience with this stuff.
Car: 87 IROC
Engine: 5.3L
Transmission: Jerico
Axle/Gears: Aluminum 8.6 w/ T2R
Re: Raising Idle While In Drive?
Idle speed may fix the stalling but not fix the issue. What I mean is that you probably have something else that is wrong that is causing the stall. Start by checking for codes.
Car: 86 IROC-Z
Engine: 370 LQ9
The car seems to just stall out when you add stress to the motor(when warm); like turning the wheels or using the power windows. So I wanted to just program a chip for the mean time.
Car: 86 IROC-Z
Engine: 370 LQ9
Can anyone tell me what to adjust to raise the idle speed while in gear? Is it the Idle RPM vs Coolant Temperature table?
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
