why no PE event in WU log?
Old Sep 30, 2008 | 02:05 PM
Ronny's Avatar
I have been noticing in my recent logs I see AE event when I should but no PE?
Did a WOT log this AM to verify issue. At 68 MPH I went to 98% TPS and held it down for about 6.50 sec. 4 gear of 5. No where in analysis do I see PE(y). AE timed out in exactly one sec. DC 45-50%. sPW peaked at 5.0 during AE. At end of WOT run the NB 02 showed 27-31 mv. I did not log WB but I suspect I recall on WB gauge I saw around 15.0/1?? RPM's peaked at 3650.
My tables show PE enable at 38-41% TPS.
I used to see PE on WUD light.
Any ideas?
Old Oct 2, 2008 | 10:39 AM
Ronny's Avatar
Re: why no PE event in WU log?
ttt
Old Oct 3, 2008 | 12:51 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Either the PE enable parameters are not set to go into PE mode. Or you updated the WUD and didn't update your BIN version. Early on in the EBL Classic development there was a change to the PE mode status flag.
Best bet is to zip-up your current BIN along with the current WUD you are using and email them to me. I'll take a look to see what is causing no PE and let you know what the issue is.
RBob.
Old Oct 3, 2008 | 01:30 PM
Ronny's Avatar
Parameters set to 38-41 TPS% So That is OK unless there are others I am not aware of.
That is exactly what I did. I updated WUD to latest edition earlier this summer. How does one update .bin version? Should I email you .bin or do you want me to handle correction in .bin? I will email you .bin around 530 pm from home if I dont hear from you B4 500 pm CST.
Scratch 530 pm wife has plans. will do sun PM.
thanks again.
Old Oct 17, 2008 | 09:41 AM
Ronny's Avatar
Thanks RBob for the updated .bin. That took care of it!
Silver Spear
South East Region
18
Dec 4, 2015 09:59 PM
L98GTA87
Oct 19, 2015 10:43 PM
FormulasOnly
Oct 2, 2015 05:52 PM
BWilcox
Sep 20, 2015 12:19 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
