S_aujpV4 idle SA question
Old Oct 3, 2008 | 02:43 PM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Trying to fix an idle sure issue.
Going through the bin, double checking my settings and in the flags/switches I find
"V4OPT 1, b4, Use Idle SA Table 81FD" Hex address 098E, Bit 4
This is enabled
I cannot find the table referenced to see if I need to alter it....
Is it just a typo and its really referencing
"Spark ADV Closed Throttle Vs. RPM" Hex address 01FD
If it is just a typo, then I've already modified this table and need to find or add the other table.
I did search for this table here, and only two threads turned up
https://www.thirdgen.org/forums/diy-...ighlight=l81fd
thanks
-jason
Old Oct 3, 2008 | 05:21 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: S_aujpV4 idle SA question
Not a typo, just symantics.
the $8D bin has a $8000 offset so when looking at the address in TP you would se 01FD when actually its position is 81FD.
Basically that flag removes the use of the closed throttle SA table.
All SA for any TPS (Except PE) is taken from the main table values.
(+/- any modifiers of course)
Old Oct 3, 2008 | 08:35 PM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Ok, that makes sense
I was just trying to use the features of TP, and the search engine here to find the answer.....
Thanks!
-jason
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
