strange issues
Car: 1992 GTA
Engine: running
Transmission: working
Axle/Gears: both
strange issues
Hello, all
I am having some strange issues after my ecm lost power/connection with the prom. I had everthing very close in the BLM department almost 128/128 at most every point in the rpm range ( verified by wb ) after my power failure the car was running horribly, so i loaded the same bin back into the prom to see if it would help the problem, it did not, so i hooked my diacom up to the car and noted the BLM's were pegged at 160 at idle,
so i turned the fuel press up to comp and the BLM's have returned to normal, but i am now at a MUCH higher pressure 51# PSI with vac off and 45# with it on.
The car used to run with 39-40 with vac off and aprox 32 or so with it on , any ideas? mods if this is in the wrong spot please move it , thanks GTA
so i turned the fuel press up to comp and the BLM's have returned to normal, but i am now at a MUCH higher pressure 51# PSI with vac off and 45# with it on.The car used to run with 39-40 with vac off and aprox 32 or so with it on , any ideas? mods if this is in the wrong spot please move it , thanks GTA
