Runs very lean at idle
Old Oct 23, 2008 | 12:14 PM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Hi,
what causes this.At idle Blm&Int=108,Innovate wb shows 16...18afr.Lambda is one wire bosch,and it is ~10" downstream from exhaustport at cyl 5 primary(coated Slp tri-y's).Crosscounts go up and down.When running open loop(cold engine),afr is more steady.When goes to closed loop,afr is unstable and goes lean(16...18).
Ecm is -870 with Lsracingchips tune.Engine is 355,eq vortec's,hotcam,stealthram,58mm tb,24lbs fms injectors(47psi),msd probillet+blaster2+6A box,slp tri-y's.
eightsixseven
Dec 16, 2024 01:50 PM
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Logan Bryant
Aug 27, 2015 11:52 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
