TunerProRT data logging
Old Nov 3, 2008 | 02:04 PM
the_target's Avatar
Ok I am very new to this. I have a 1618625 ECM using a E6 config. I am trying to datalog with tunerpro but cannot seem to find the correct ADS file it needs. I keep getting a XDF mismatch error. Can somebody point me in the right direction.
Thank you
Old Nov 4, 2008 | 09:25 AM
zap's Avatar
zap
Re: TunerProRT data logging
You will get this error when trying to use the wrong XDF for the bin or the wrong bin for the XDF file.
Old Nov 4, 2008 | 10:31 AM
Ronny's Avatar
look on craigmoates website under downloads.
Old Nov 4, 2008 | 12:00 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Originally Posted by the_target
I keep getting a XDF mismatch error. Thank you
That is the message when your ADS file is not linked to the XDF for datatracing while logging with th ADS definition.
Under the header info of the XDF you can set the path to the ADS file you are using.
DXF is for the bin editor
ADS is for the datalogging definition.
If they are linked together you could see the values highlighted in the tables when logging/editing at the same time
Old Nov 4, 2008 | 04:25 PM
the_target's Avatar
Thank you all for your help. I will try again this weekend.
Old Nov 18, 2008 | 02:28 PM
the_target's Avatar
Ok so I got the files needed and I am able to connect to the ECM and it looks like its logging. Shold I be able to see active logging in the DASH part of the ADL logging screen. I have set it up but I get random numbers in the boxes while I am logging. I was hoping to be able to monitor while I was driving with realtime screens. is this possible ?
Old Nov 19, 2008 | 08:10 AM
the_target's Avatar
Ok update. looks like I have to correct file but I am getting noting but packet errors when trying to monitor. I e-mailed Mr Mangnus ( Great guy ) so we shal see what he can come up with. as another datapoint I was able to log with datamaster with no issues but I would rather use tunerPro.
Falcon50
Aug 22, 2020 03:26 PM
L98GTA87
Oct 19, 2015 10:43 PM
bjpotter
Oct 4, 2015 07:48 PM
BWilcox
Sep 20, 2015 12:19 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
