Novice, need info about programming
Old Nov 19, 2008 | 04:44 PM
zhunter's Avatar
I have a 1993 chevy truck currently with a 454 with over 200k and am planning on installing a rebuilt 350 tbi with an lt1 cam, vortec heads, edelbrock carb intake w/adapter plate for tbi and the 454 tb. I am wanting to program a chip and needing some advice, the truck is currently still running, I was just needing some guidance on the programming for such a combo.
Thanks in advance!
any input, or reccomendations are welcome.
Old Nov 20, 2008 | 08:17 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Novice, need info about programming
First thing to do is to find out which ECM or PCM your vehicle is running. With that you can find out what type of hardware is required to tune it.
Pull the ECM/PCM down and get the Service No from it. Then post back with that info.
RBob.
3rdgenparts
May 21, 2016 11:50 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
ULTM8Z
Oct 2, 2015 01:25 PM
Linson
Oct 1, 2015 09:50 PM
