Need help on bin stacking REVISITED
Old Nov 26, 2008 | 08:39 PM
hotrodta57's Avatar
Car: 1988 T/A
Engine: L98 Highly modified
Transmission: TCI 700R4
Well, found the stacking utility, but not sure how to use it. I have 16k bin ($6E ARAP), 32k configuration on the Prominator. In Tuner Pro bin stack utility... Bin size= 16k, Chip size= 32k and Block size= 32k it only gave me one layout location. I changed Chip size to 64k which gave me two locations and I created stacked file, uploaded it to my car and it still won't run. Need help! Thanks
Old Nov 26, 2008 | 11:31 PM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Re: Need help on bin stacking REVISITED
Most of the bin stacking stuff is for individual chips not emulation.
My Prominator works fine at 16 and 16. Just save the bin and load it (exactly as it is saved by TunerPro).
The 8 (16K bit programs) in a Prominator are stacked, but with different starting points set by a switch, not by a software starting location. I don't know what the default bin starting location is.
Why did you get a 32 when you use a 16? There may be Prominator software differences.
You might want to ask the person you bought the Prominator from (Bill Hitchcock?).
Talk to Bill.
Old Nov 27, 2008 | 08:45 AM
hotrodta57's Avatar
Car: 1988 T/A
Pandin,
Thanks for the reply. I read in one of the threads on TGO where Bill recommended getting the 32k setup. Sent message to Bill, but as it is holiday waiting for a reply. Will try setting everything to 16k in bin stacker utility and see if that works.
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
efiguy
Sep 27, 2015 01:30 PM
