lean on downshift, instant boost, not enoguh fuel
Car: Chevy truck
Engine: supercharged 355 tbi
Transmission: NV4500 manual
Axle/Gears: 14 bolt w/4.56 and detroit locker
basicaly my problem is this, im tuning my truck that runs up to 13 pounds of boost on a one bar map sensor, i can do this relatively easily becasue the boost stays consistent to rpm... most of the time. its a twin screw whipple so the problem is, when i hit the gas crusing and it downshifts, the boost is right there and instantly hits about 9psi at a very low rpm. so it will hit 16 or 17:1 for a split second untill the shift is done, once its in gear and under load again everything is ok. is this something im just going to have to live with? is it safe? iv got plenty of fuel on tap, iv got a walbro high pressure pump and 80# injectors running at 30psi when the boost referenced regulator kicks in.
Car: check
Engine: check
Transmission: check
Re: lean on downshift, instant boost, not enoguh fuel
I don't think anyone is going to say that the lean spike is safe... that's getting out onto a thin branch.
As for helping to cover it see if there is enough delta MAP for more AE. This may work because: as you hit the gas the MAP will increase with dMAP AE added. As the downshift completes the RPM will go up and the MAP will either fall a little or level out. That will stop the dMAP AE. Can try it and see how it works out.
With an auto more dMAP AE can be used then with a stick trans. Less likely to flood the engine with fuel from large dMAP transitions.
Hopefully the Walbro isn't one of these:
http://www.turbobuick.com/forums/gen...mp-update.html
RBob.
RBob.
Car: Chevy truck
im going through my tables and i dont see any table for delta map? i do not have the 7747 ecm like in the older tbi pickups. i cant remeber what ecm i have right now but would this explain my lack of having a delta map table?
Car: Chevy truck
nobody has a problem with this but me i suppose?
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
You have the 7427 ecm.
You have a table that says acceleration enrichment vs. differential MAP...start with that.
Also, if you are in closed loop, you might want to richen up the o2 sensors on high map to help with that as well.
Car: Chevy truck
thanks yenko, i understand i just need to add to that to add more fuel, i see how you added some in your bin compared to my stock one. but i don't understand what Useconds means, should i just take this as an imaginary number? i like to understand what things mean...
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Basically, its the amount of time the injector stays open to spray fuel into the engine......(just the basic meaning).
Car: Chevy truck
i started a trend, my brother and his buddy went in half on efi live to do their nbs trucks, ones a d max, the others a 6.0 with a cam. i was looking at the efi-live stuff, and man there is tons of info on that, whole tutorials and everything. im going off on a tanget, but anyways, thanks for the help once again yenko.
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
No problem....there are actually some tunes out there for the D-max for a better start.
Keep the D-max to a 80-100hp tune b/c anything over that and the Allison transmission will be toast.
With the 6.0L and cam (non-ls2), get the timing to about 22-23 timing and that will help the idle a lot and about 26-27 WOT(at first on 93 octane). Then its all about fueling.
Car: Chevy truck
honestly, i don't think they know what they are getting into lol, but you dont really have to on the duramax, you can buy a awesome tune for 100 bucks from kenedy racing and just load it up... and fry your trans. as for the 6.0, he could almost just not even touch the tune on that thing and hed be fine, and the duramax is more than fine with the diablo sport and the boost turned up, hes already ruined the turbo from playing with the waist gate and making 30psi out of the stock ihi turbo, now it backspins and every time you let off the throttle, the trans has been limped a few times also. so i think they both waisted money lol, should be interesting what they do to their poor trucks, especially the duramax.
Ghettobird52
Jul 5, 2024 11:18 PM
