please help mini ram 383 afr headed
Old Nov 30, 2008 | 02:16 PM
2fast4love's Avatar
ok i recently bought a 383 iroc with a mini ram on it it also has a zz 383 cam in it with 1.6 roller rockers. well the problem is the car has the idle surging i already cleaned the iac sensor and replaced the spark plugs and its the same. i also adjusted the tps to 52 and the the fuel pressure is at ideal. i have thrown a maf code once while driving and it disappears after the car has been restarted. im killing myself for this please help also its and 88 thanks everyone
Old Dec 1, 2008 | 03:45 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: please help mini ram 383 afr headed
You have a couple of items that need to be tuned in for that setup. What are you using for data logging and chip burning? Which MAF code is it?
RBob.
evilstuie
Jan 9, 2020 08:29 PM
gixxer92
Sep 1, 2015 04:32 PM
Dialed_In
Aug 20, 2015 01:45 PM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
