How to disable closed loop and tune in open loop using tp rt
Car: 91 camaro RS
Engine: superchargered 350
Transmission: t56
Axle/Gears: 4.10
Is there a setting in tuner pro rt that disables closed loop for tuning purposes? If so, how?
Car: check
Engine: check
Transmission: check
Re: How to disable closed loop and tune in open loop using tp rt
Look for the closed loop enable temperature and set it high.
Did you see my response to your mask/bin question on the DFI & ECM board?
RBob.
RBob.
Car: 91 camaro RS
Transmission: t56
Axle/Gears: 4.10
Street Lethal
Apr 30, 2019 12:14 PM
