EGR Disable E6 Definition File
Old Dec 19, 2008 | 05:48 PM
dave w's Avatar
I could use some help disabling the EGR on my 93 GMC, which is the E6 Definition File. I have a couple screen shots from my Tuner Cats Software, Switch and Constants Tables.
Thanks,
dave w
Attached Thumbnails EGR Disable E6 Definition File-egr-disable-2.jpg   EGR Disable E6 Definition File-egr-disable-1.jpg
Old Dec 19, 2008 | 10:31 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Re: EGR Disable E6 Definition File
I do not have tunercat; I use Tuner pro. just set your (Disable EGR if MAT < X) to some high number
edit: in your constant table, set every number that has to do with (EGR on) to a very high number
HTH
Old Dec 21, 2008 | 11:28 AM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
I thought if you used tables/functions and set EGR duty cycle vs. LV8 and RPM to 0 so it doesn't expect the egr to do anything. I don't really know though.
Old Dec 21, 2008 | 12:44 PM
dave w's Avatar
I think changing the following ECM switch and constant settings will work?
Attached Thumbnails EGR Disable E6 Definition File-egr-disable.jpg   EGR Disable E6 Definition File-egr-disable-1.jpg
Old Dec 21, 2008 | 04:40 PM
I haven't seen that flag and I'm playing around w/ a $6E. hmm... looks like it'll work though.
Old Dec 23, 2008 | 12:12 AM
dave w's Avatar
The ECM I'm working with is 16168625 definition file E6, that uses a 27C512 chip. I think the 6E definition file is for ECM 1227165 that uses a 27C128 chip.
dave w
Old Dec 24, 2008 | 12:19 PM
dave w
right, i think the definition file I'm playing with is for a 350 tpi camaro. I'm just hoping to find some similarities so I can learn by watching what others do.
pacoelrapido
Sep 11, 2015 02:41 PM
swerve-driver
Feb 7, 2003 02:39 PM
r90camarors
Sep 1, 2002 09:46 AM
JPrevost
Apr 24, 2001 09:55 AM
Blade
Jan 29, 2001 06:37 PM
