Rough idle. Need help or advice.
Old Sep 11, 2015 | 12:05 PM
pacoelrapido's Avatar
The car is TransAm 89 305 tpi. The problem apeared after long-lasting park. Before that everything was ok. Rpm wildly jump at idle. Seems like timing moves in wrong direction or like it trying to find right rpms and timing but without any fortune. Computer does't give any mistake codes. If I unplug est connector engine runs perfect. Egr and air pump deleted. IAC and TPS changed and checked. Do you have any ideas?
I can attach some .xdl files but i don't know how to upload 'em there.
Old Sep 11, 2015 | 01:59 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Rough idle. Need help or advise.
Sounds like an age old vacuum leak. Rotted or broken vacuum line?
Old Sep 11, 2015 | 02:24 PM
Actually sounds like a nice idea! May be you know a nice way to check?
Old Sep 11, 2015 | 02:41 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: Rough idle. Need help or advice.
Just start looking and following all the line and check condition of them. If your fingers get black all over them, they're probably shot.
Check under front and back of plenum, EGR Solenoid, EGR, Brake Booster from rear of plenum, vacuum ball in front drivers fender, cruise junction tee, and so on. There's quite a few
Mark_ZZ3
May 24, 2018 01:02 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
Jlanz55
Sep 29, 2015 08:55 AM
