How do you expand tables in Tuner Pro RT? For example, my extended spark tables only go to 5400rpms, but my extended fuel tables go to 6400 rpm.
is there any way to extend the spark tables, or even the fuel tables. What if i want to shift higher than 6400? then what?
thanks for the help
thanks for the help
The code it self needs to be modified, "patched", in order to do what you want to do. It's an advanced operation. Then after the code is in place, the xdf can be modified to show the extended tables.
the s_aujp has the tables extended in it. its worth the copy over just to help learn stuff. also even thou your table ends. it doesn't really end. it does some math with your last value and carrys it on out. unless your seeing something on the wide band you don't like. I wouldn't worry much.
